2024-06-30
10:32 AM
2024-07-01
11:54 AM
When i export a plan to autocad, all labels that uses GDL are not exported correctly , the text alignement is wrong,
Here is the Zone label , and it's settings
In autocad, it looks like that :
it's imported as a Block,
When i open the block , the text anchor points are in the middle , where they should be, and the text alignement parameter is set correctly to " Center" :
i noticed there is some extra "space caracters in the text field , :
When i delete that extra spaces, it looks correct,
Does someone knows this issue and how to fix it ??
2024-07-03 10:27 AM
still didn't find a solution, any suggestions please ?
2025-05-21 08:46 AM
Notepad does not interperate it as a simple word space, but a word space and a forward slash...
BALCONY/ / / / / / / / / /
And it is only the last line...
