Archicad door label on plan by level (story)
ladystarlight
Can I write on plan the door stamp by story, for example door 1 - story1 ,2 or 3... I checked everything and didnt found the answers 😞
2 ACCEPTED SOLUTIONS
LeeJaeYoung
I think what you're asking is to create a new GDL.
with home_story and n = REQUEST("Home_story", "", index, story_name)
It seems possible to create a new GDL Label.
AC27 on window 11
You can create property that will combine door ID and storey number or storey name:
CONCAT ( {Property:General Parameters/Element ID}; "-"; STR ( {Property:General Parameters/Home Story Number}; 0 ) )
undefined
BIM Manager at SIEBERT+TALAŠ
www.sieberttalas.com
8 REPLIES 8
LeeJaeYoung
AC27 on window 11
ladystarlight
thanks, it helps me to understand what i  have to do, but also it takes many time to custume label for door or is there any other whay to do it inside door stamp marker from classification and properties ?  see attached photo
undefined
I don't use it.
However, I study what I need and use it after modifying it.
And I've never tried to put a level into a door or window. Because it is fully expressed in the schedule.
AC27 on window 11
undefined
ladystarlight
Thanks it works now, I needed this numbers on plans in door ID and according them are all door shchedules.
ladystarlight
Congratulations on finding the answer. ^^
AC27 on window 11
ladystarlight
thanks, CONCAT ( SPLIT ( STR ( {Property:General Parameters/Home Story Number} ), ".", 1 ), "/", STR ( {Property:General Parameters/Element ID} ) ) this is exact answer what i was looking for 👌
