2011-03-01
10:23 AM
- last edited on
2023-05-23
12:00 AM
by
Gordana Radonic
2011-03-01 08:23 PM
2011-03-02 01:34 AM
2011-03-02 08:37 AM
2011-03-02 01:45 PM
2011-03-02 04:56 PM
2011-03-03 04:22 PM
Steve wrote:Well, yes. Apart from long surveyor's tapes (20m, 30m), metal tapes are marked in mm along their full length.
How is 1880mm a more useful dimension than 1881mm ?
Of course this is comming from someone who can't comprehend why people would work in mm anyway. Do you have some sort of tape measure that is marked off in mm even past a meter?
2012-02-16 06:32 AM
2012-02-16 08:18 PM
2012-02-17 05:21 AM
kliment wrote:I'm afraid I have to disagree, kliment - construction is not millimeter perfect, hence the 5mm tolerance level that is quite standard (here, in any case). To expect more precision from a builder is unrealistic. Certainly, if there is a specific material or object that has a specific dimension, this should be allowed to be presented as a "true" dimension if necessary, but more often than not the rounded dimension is more than adequate.
While I understand why you ask for this, I think it has the potential of being used for concealing careless or incompetent work, so I prefer it the way it is now.
