architect
Door quantity text, schedules
On schedules, is there a way to change the text that says R (1) to DBL (1)?
2 Solutions
Ricardo Lopez
Hi @architect
You could create a new string type property for doors with a conditional expression where you could write whatever you wanted (ex: text1 and text2).
IF ( {Property:Window\/Door/Orientation} = "R", "text1", "text2 )
This property must be available for doors (and also windows if you want)
Regards.
*NOTE: ";" or "," may differ in expression depending on operating system regional settings.
Ricardo López, M. Arch.
Go to post
The problem with 'Orientation' is it is either left or right (L or R).
Even when you place a double door, you place it in the same manner as a single door, so as far as Archicad is concerned for the orientation, it is still left or right.
You can schedule other parameters from the objects, maybe there is one that says 'double' or 'single'?
Or as Ricardo has suggested (but doesn't work in this case, as it is just changing L to Left and R to Right), is to create a property object that you can use.
I could be a property where you manually type what you want - you could just add a custom text field in the schedule for that, so I wouldn't necessarily do this in a property.
It could be a property with an expression to determine if it is double or single based on the door settings - but if this is coming directly from a parameter in the object, then just schedule that parameter.
Go to post
3 Replies 3
Ricardo Lopez
Hi @architect
Regards.
Rubia Torres
Hi @architect,
Thanks to Ricardo and Barry's contribution here, we went through the steps to answer your question in our Insights blog with the Tip of the Month. Worth a check here.
Cheers!
Rubia Torres
Community Expert | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
