2014-11-06 04:52 AM - last edited on 2023-05-18 01:29 PM by Gordana Radonic
2018-04-23 03:18 AM
2018-04-23 08:44 PM
2018-04-24 02:59 AM
dcerezo wrote:That's Archicad for you.
It looks like we're choosing which is the best way to skin the cat.
dcerezo wrote:I think that is the biggest problem - the plan is not a symbolic view like a real 2D plan.
Right now we're really liking the 3D Documents option. For doors, we're selecting the option to show it open in 3D that shows the door leaf open. Then we just add an arc line for the swing. Graphic Overrides pretty much takes care of the rest.
dcerezo wrote:If it works for what you want then that is perfect.
So far, we haven't found a hitch with the 3D document route. But who knows where it will go.
2018-04-25 10:50 PM
dcerezo wrote:[As a general principle: whenever something is requiring too much labor, it means you are not using the program right. Lots of people have been using the program for decades for much larger projects.]
To do the same thing in ArchiCAD, we could do 2 things (however, I think there's a 3rd we just discovered)
1. Detail view. The problem here is that these are all 2D elements. I can't tag the windows. I can't tag the doors. I can't tag zones, etc. Rebuilding is a pain and what if we forget. Plus lots of stuff re-sets when you Rebuild.
2. So we went with the Live View route that Barry showed. But we had to create sooooo many layers. Such a pain in the a**. We had to create Dimension layers for each unit, wall type tags for each unit, etc. AGAIN, the reason is because I just create one dimension layer, the dimensions from Unit B show on Unit A's enlarged plan....because they're only 12" apart.
We may have a 3rd way...what do you guys think....and why has no one mentioned this before? We are using the marquee tool to create a 3D Document floor plan.
2018-04-26 11:24 AM
2019-01-10 07:34 PM
2019-01-10 07:56 PM
2019-11-03 10:07 PM
dcerezo wrote:I hear your pain. I've come over to ArchiCAD from a decade of Revit. There are some things about AC that are great and then there are some that are just retarded. I can't believe that they call themselves BIM leaders. No live details, no ability to do plan callouts, no ability to create sections anywhere (Yes, I want to create sections of sections of sections if that makes my job easier). Everything takes dozens of clicks to accomplish. And don't even get me started on the antiquated parameteric modelling solution - GDL. Revit's family modelling and type based parametrics are simply superior (but what about file size, blah blah blah, who cares get a better computer...)
We are relatively new to ArchiCAD, having come over from Revit, but this issue with Enlarged Plans and Details is really making us regret making the switch. The time it takes to do unit plans, enlarged bathroom and kitchen plans, enlarged stair plans, and corresponding annotations is insane.
What used to take us maybe 5 min tops, per unit plan, in Revit, is taking us like an hour in ArchiCAD because we have to create this layer or that, shut that one off, create a layer combination for this...it's ridiculous.
My question to all of those folks who have been using ArchiCAD for a long time is....really...is there no easier way?
2019-11-04 12:25 AM
2019-11-05 03:38 AM
