Export then Import a favorite CW Custom panel
Gisele
How to export then Import the custom door that I have saved in the favorites as GSL-CRTN-Wall-Door?
(I do not want to export/import the entire library. Alos, I need to export the door from one computer and import it in another computer).
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
2 ACCEPTED SOLUTIONS
4 REPLIES 4
Hi Gisele,
Open the Favorites Palette. There you'll find the Import/Export Dialog when you click on the Gear Icon:
Be sure to use "Selected Favorites Only" if you want to export only one favorite.
Best,
Bernd
Bernd Schwarzenbacher - Archicad Add-On Developer - bschwb.com (Add-On Downloads & Articles)
Could you please send a screenshot showing the Impot/Export icon?
Or a step by step?
Sorry, I don't know what you mean with "Import/Export icon". My best guess is, that you mean where to find this specific  "gear icon" maybe?
In my previous answer, I'm using the "Favorites Palette". It's located under the menu "Window -> Palettes -> Favorites". (Step 1 in following picture)
It looks very similar to your screenshot, but it's a different Window! (You are accessing the favorites in the Curtain Wall Tool Settings)
I've made this step by step guide in case you are stuck at a different step.
Thank you for the step by step. It worked!
