Stefan Videnov
Graphic override - Not orthogonal elements
Hi everyone,
Recently i've been working on adding a number of check features to my ofice's template.
I would like to integrate a graphic override which colors all 2D and 3D elements which are not oriented at 0, 90, 180 or 270 degrees. Preferably I would be able to specify ranges - for example if the orientation is between 89 and 91.
Currently we are using an auto label that comes with our KeyMember edition which works like this one:
https://centralinnovation.com/technical-resources/tips-and-tricks/check-non-orthogonal-walls/
It does the job quite well - all labeled elements that have bizare rotations have their angle displayed in red, Problem is that it's with labels and then you have to manage all the labels that you've created.
If the label can read the angle then a Graphic override should also be able to so, but I can't seem to find a proper parameter listing.
Ideally it shouldwork like this, but for angles..
https://community.Graphisoft.com/t5/Document-articles/Graphic-Overrides-series-Color-Zone-By-Size-by...
Any ideas?
1 Solution
scottjm
Mentor
99.9% sure this isn’t possible natively GO’s. The label has to do a bunch of calculations in GDL of the delta x and y of the wall, beam etc to work of what it’s placed angle is.
The only way I can think to get it work with a GO is a writing an API that would write the calculated placed angle into a property field, and the GO could read that property value.
Go to post
scottjm
Mentor
