2024-02-20 08:40 AM - last edited on 2024-02-24 09:33 PM by Laszlo Nagy
Hello everyone,
2024-02-26 03:04 AM
Here is a video to showing how to do what @MitchD, is suggesting above.
https://www.youtube.com/watch?v=Ohy-ofjBe1c
Hope that helps.
2024-02-26 03:11 AM - edited 2024-02-26 03:12 AM
Hi @Barry Kelly, I understand that view pen set method and I personally do not use it because I prefer to set up everything in my model including the elements in my template.
2024-02-26 03:19 AM - edited 2024-02-26 03:33 AM
Could you explain a bit your workflow? Im really not super fond of pensets either, but sometimes not fighting the software and going with flow helps a lot. Once you have it, you really dont need to think about lineweights that much. Or what is it you are finding difficult?
2024-02-26 03:48 AM - edited 2024-02-26 03:59 AM
When creating a template and setting up my wall types first. The composites are set with lines there and then, that’s it, all done, forget about it. Then the doors and window line defaults are set up for each view or cut, that’s it, forget about it. (Of course you also set up all your other elements too)
A new version comes out with windows with pink fills (Should just be a MVO), where are they so I can change them ? The dialogue box gets greater and greater and I start looking for the lines and fills to change them, it takes a very long time.
Pen sets for each view, GO’s, when you start applying these levels of complication, it gets very messy when you need to look to change a single line. Hence my suggestion to have the onscreen true line weights leading to a list of lines showing on my screen so I can quickly edit an offending line. Without having to go for a search through endless dialogue boxes to find that offending line. Can take up to 1/2 hour sometimes especially with CI tool elements.
I live with it because every software will have things we don’t like about them. Yes in CA all lines are on the layer with each element and very easy to find and change when opening up your layers dialogue. AC doesn’t have to be so complicated when it comes to looking for offending lines to change them. AC is my preferred CAD software program and it’s great.
That’s what concerns me.
