How to update master title block to reflect project changes?
Zdenko
trying to figure out how to make the master project border stream-line with project changes. any suggestions on work flows or links to them concerning project revisions, approval etc., not sure how change manager works with the text ID elements that i have placed in our project master border. TBH not sure what questions i need to ask for help?
Operating system used: Mac Intel-based Sonoma 14.5
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
Eduardo Rolon
At first glance:
For the vertical ones you will use the "Revision History Detailed 27" object placed on a Master Layout.
For the horizontal ones you will use autotexts.
Recommend to read up the help file
For the attached image:
  • Revisions = Object
  • Issues is an Index that lists Change Manager Info
  • Project data are regular autotexts
Index Settings are:
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
At first glance:
Index Settings are:
AC29 US/INT -> AC08
another Moderator
Zdenko
thank you @Eduardo Rolon! appreciate the short tutorial 😀 i did attempt to read the help but as usual time is always short. regardless thanks and will do a better job of explaining myself next time.
Sequoia 15.1.1
Setup info provided by author
