Rene Pahlavan
Level Dimension not registering a dimension
Having a strange issue of the Level Dimension not dimensioning to Sea Level on a mesh. Two meshes next to each other - one shows properly, the other shows #toPZvalue (even though the setting is to Single-Value Visible Top to Sea Level and Gravity to Mesh is turned on - screenshots attached). Does anyone know why the to Sea Level dimension is working on one mesh as it is supposed to, but not the one beside it?
Operating system used: Mac Apple Silicon 14.5 Sonoma
AC27 (Apple Silicon)
macOS Sequoia 15.1.1.
MBP M3 Max (16-inch 2023)
Setup info provided by author
4 Replies 4
Do the meshes appear similar in 3D?
Lingwisyer
Guru
It is not associated with the mesh? It can become disassociated if you accidentally move the reference node.
Ling.
Rene Pahlavan
Yes, other than their thickness, the meshes are identical.
Rene Pahlavan
No, I have not accidentally moved the reference node; and I have tried to add level dimensions all over the mesh - they all show this result even though gravitate to mesh is on. (the level dimension tool operates correctly on all other meshes and slabs in the view).
