2020-08-24 04:12 PM - last edited on 2023-05-22 11:51 PM by Gordana Radonic
2020-08-24 05:37 PM
2020-08-24 05:59 PM
2020-08-24 06:14 PM
2020-08-24 06:20 PM
2020-08-24 06:25 PM
2020-08-24 07:51 PM
2020-08-25 03:09 AM
2020-08-25 11:48 AM
Lmpessoa wrote:Unfortunately there is no such option (yet). But you can always put your wish here on the wishlist.
but I still miss those alternating line colours since they help reading the resulting tables and look forward to even the simplest option to achieve that result.
I'm aware of favourites and am yet to configure on my own template, I just think there could be an easier/simpler way of doing this.Yes. The process of creating a solid template is a bit time consuming, but the return in productivity is gigantic. You will also see that this process is much more fluid on Archicad.
2020-08-25 12:56 PM
Braza wrote:
Regarding the Section Marker: You can create custom Section Markers, but I am pretty sure you can achieve it with the standard ones. Could you give us a screenshot of exactly what you want?
Lmpessoa wrote:
As for the cut line, I'm attaching a screenshot of what I had to do.
Barry wrote:
As this is not a discussion about Archicad and is more about how to document in Archicad, I have moved this post to the Construction Documentation section.
