Only outer lines of complex wall
Zendrix
Hi!
I have a set of stone walls which are a complex profile (stone+plaster), but for this phase i would like it to show it as a single and simple wall, with only the exterior and interior cut lines, as in the picture.
I found a workaround by eliminating the lines from the complex profile menu, but for sure there a way to override those lines adding a new rule on the overrides tool, no?
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
Florin Luca
Hi Zendrix, try  checking on Hide Skin Separators in the GO rules.
AC27 Solo US, latest build
macOS Ventura 13.6
iMac | 3.8 GHz 8-core Intel i7 | 40 GB RAM | AMD Radeon 8 GB
Florin Luca
macOS Ventura 13.6
Zendrix
Thank you so much!
Z
