Sam Parish
Parallel Projection - Top View Skewed
We tend to use the parallel projection top view for shadow mapping of a proposed project, it's not often that we need to do it but when we do I go into axonometric view then click the top view button in the 3d projection settings window.
It has been a while since I've needed to do this so I can't remember if it was the same previously but it now is offset by 2.6 degrees so the x and y coordinates read 2.6 & 92.6 respectively when I click the top view button.
It is easily fixed by correcting to 0/90 manually but I don't know if someone has changed something or if it is the way that the project is set up. I have tried this on several different projects across multiple computers in the office and have the same result everytime.
If anyone has any experience with this or advice on how to fix it it would be greatly appreciated.
ArchiCAD 24 NZE FULL
Windows 10 Pro 1909
Intel Core i7-6700; 32GB RAM; AMD RX480
1 Solution
It is using the projection co-ordinates that you last used in the 3D window.
Rotate your model in 3D and then go to project settings and you will see it uses the settings you had in the 3D window.
Pressing the 'top view' button only resets the 'Z' axis.
The 'X' & 'Y' stay with the same values.
So you have to reset them before or after pressing the 'top view' button.
Either by typing the 0/90 values in or just drag the camera icon in the settings dialogue so it is exactly at the bottom of the image.
Go to post
4 Replies 4
Lingwisyer
Guru
Not sure there is an interaction, but might there be a custom north point in your model space?
Ling.
Sam Parish
Cheers Ling,
We have set the project North to a custom value. We typically set the plan on a sensible axis and then arrange the site around it but in this particular case project North is at 54.69 degrees. I have tried it with other projects with different projects Norths and they still have the same 2.6/92.6 input.
I just tried it with a fresh ArchiCAD NZE standard template file with no custom project North and it is the same issue.
Windows 10 Pro 1909
Sam Parish
Thanks, Barry,
That has fixed it, I kept manually changing the numbers but it would always set itself to custom and then the top view would always go back to 2.6/92.6. Adjusting it by pulling the camera around works even after closing the dialogue.
Sam
Windows 10 Pro 1909
