Edoardo B_
Show "Wall Surface Area" in zone stamp
Hello everybody!
I'm looking for a way to show the "wall surface area" value in the zone stamp.
I tried to look into Classification and Properties but you can only have the Walls Inset and the Walls perimeter and no Surface Area.
So I tried to add a new Property from the Property Manager but I am not an expert in that department and I can't seem to make it work. I create a new property but I must be doing something wrong since said new property once created doesn't show in the list.
Edit: so I've been looking out for some tutorials and it looks like this issue is not "normal". All the tutorials I could find simply created new properties and then add them to the zone stamp through the Classification and Properties settings. I, on the other hand, can see just some of the properties I create, but not all of them. Specifically it seems I can't see the ones that need to extrapolate the info I require from parameters that are not strictly related to the zone settings such as the wall surface area and the windows area.
Funny thing is those properties exist and work if I use them to create a schedule. The only issue here is I cannot add them as values into the zone stamp.
Schermata 2021-10-21 alle 14.07.13.jpgSchermata 2021-10-21 alle 14.09.08.jpgSchermata 2021-10-21 alle 14.10.49.jpg
MacBook Pro (15-inch, 2016) / CPU: 2,9 GHz Intel Core i7 quad-core / RAM: 16 GB 2133 MHz LPDDR3 / GPU: Radeon Pro 460 4 GB / macOS Big Sur (v. 11.6)
8 Replies 8
Please refer to following thread:
https://community.graphisoft.com/t5/Document-Visualize-forum/Expressions-Property-Value-type-dont-sh...
It talks about some Properties not being available in Graphic Overrides.
I think this is the same in case of Properties in Labels. For example, you are in the Floor Plan, but a Property generated based on Volume is not available. The Wall's 3D model would have to be generated to be able to calculate its Volume so it can be displayed in the Label. I think this is the reason why certain Parameters and Expression-based Properties based on these Parameters are not available for display in Labels.
Just as a test, would you try to place this same Label in a Section or Elevation and see if those Parameters are available for display in the Label? To generate a Section/Elevation, the 3D model needs to be generated, so in that case, it is possible that the Property will be available for the Label. This is just a guess, you should try it.
Edoardo B_
Thank you for your reply!
I thought the same, but there are a couple of strange things:
1) In order to produce those equations I followed some Archicad Italia official tutorials (referred to Archicad 22) and they had no issue whatsoever with this, nor they mentioned this possibility;
2) A friend of mine tried the same expressions on his machine and they work for him;
3) The default "Window Area" parameter can be turned on on the zone label and I guess windows and walls are generated together.
Then can you post images of the exact Property expressions you have defined and which Classification they were made available to and also the Element Settings Dialog and the Label Settings Dialog? Please just show one specific Property so we can focus on a single case. That way we can hopefully figure this out.
Please also state your Archicad version (e.g. AC22 INT) as there may be differences  between versions.
(It may be a good idea to include your computer specs in your signature.)
Edoardo B_
Here's the property expression
And it works technically
Here is the zone classification that matches the one of the property
And here's what I finally see when I try to add the property to the zone stamp (nothing)
Finally I use AC25 INT Build 3011.
This is curious. I reproduced the settings from your screenshots, and indeed, the Property returns a correct value if I select a Zone and evaluate the Property in the Property Manager Dialog, but for some reason, I can not select it to be displayed as part of the Zone Stamp.
Why this is is beyond me so I will forward this to GS and we will see if they have an answer for it.
Edoardo B_
Thanks!
Erwin Edel
We can display property values in zone stamp using the custom developed zone stamp that ships with the Dutch reseller subscription library. So in terms of GDL it is certainly possible.
It does require one or two actions with setting up the property, filling it out for the zone and then specifying somewhere in the settings of the zonestamp that you want to show it.
We use this a lot for zone studies where we need to be able to batch / bulk change fields and can use the excel import / export feature of properties.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Minh Nguyen
Hello Edoardo,
Thank you very much for the report and I am very sorry for the issue!
I could reproduce the bug, thanks to your detailed guide. The issue did not happen with previous Archicad versions, only with Archicad 25 3002 and 3011. The good news is that, the issue is fixed in Archicad 25 Update 2, which will arrive very soon!
I am very sorry for the inconvenience, and thank you very much for your understanding! Feel free to ask if you have any questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
