2019-12-03
02:06 AM
- last edited on
2023-05-19
07:14 AM
by
Gordana Radonic
Solved! Go to Solution.
2019-12-03 02:57 AM
2019-12-03 02:20 AM
2019-12-03 02:30 AM
Barry wrote:Thanks Barry, in the past ive never needed two though, if i grabbed the object to be moved from a point and then made a snap point it would make a middle point in the past for me. Do you know if this is possible to set up?
If you place 2 snap point circles, you should get the midpoint (so long as you have snap to 'Half' active).
2019-12-03 02:57 AM
2019-12-03 03:10 AM
Barry wrote:Thanks for that Barry.
You can set the snap options to 'Between intersecting elements', and this will give a snap midway between intersecting walls or other elements.
But it will not use objects as intersections, so in your image the vanity bench will not act as an intersection if it is an object, but will if it is a slab or fill.
But it could be that you were automatically establishing the snap guide lines just by dragging the element around and touching the edges.
This may establish intersecting snap guides that will give you a mid point.
I have never noticed a snap midway along the rubber band while dragging - unless it coincides with another guideline or edge.
This is what I would do.
Barry
