2004-07-28 06:52 PM
2004-07-29 04:26 AM
jdrulon wrote:Are you using different fills to define the 2x4 and 2x6 cores within the composites? This would cause your problem.
I have noticed that when I have cores of composite walls that are slightly different (i.e. 2x4 and 2x6 stud walls) the cores do not intersect but instead the finish carries through the intersection. Is there a way to fix this?
Also when I send a CAD file to my structrual engineer who uses autocad he would like to only see the structural walls without the finishes. Is ther a way to see only the core (structure) of a composite wall and not the whole wall? Thanks in advance for any help in these matters.This is not presently possible (though some clumsy workarounds come to mind), but it would make an excellent wish list item. A display option to show the cores only would be a nice feature.
2004-07-29 08:18 AM
Also when I send a CAD file to my structrual engineer who uses autocad he would like to only see the structural walls without the finishes. Is ther a way to see only the core (structure) of a composite wall and not the whole wall? Thanks in advance for any help in these matters.I think this is a great idea. It would make the ArchiCAD extras easier to use as well.
2004-07-29 10:16 PM
jdrulon wrote:This was put in the wish list last December:
2004-07-31 03:25 AM
2004-08-09 07:57 PM
