2023-05-21 09:59 PM - edited 2023-05-21 10:18 PM
Hi! I tried to create new fill but what I need it to be is also a "cut fill". it does not let me do it and this is exactly why I needed to create a custom fill. it does not say why I can't save it as cut fill.... also no matter what my setting is, the line showing in the middle won't dissapear and it shows like that even when using as a standard fill (not cut fill). I don't want to show any lines/fill separators in my fills, could I delete it?
please help?
Solved! Go to Solution.
2023-05-21 11:34 PM
Image fills can only be used as Drafting fills or cover fills, not cut fills
https://helpcenter.graphisoft.com/user-guide/128564/
2023-05-21 11:37 PM
Whyyyyyyyyyyyy!!😩😩😩
would you know how to remove the line when the pattern repeats? It shows in floor plan . I’m ok the patterns repeats but don’t like when line shows in the middle of it when it’s not needed
2023-05-21 11:49 PM
It looks like an issue with the original Image.
you will need to fix that to get rid of the line.
i do not get lines when i make image fills.
