Ecodesigner Beta forum
Problem when exportin gbxml
minox
Hi all, I have a problem when exporting in gbxml to Ecotect.
When I open the model in Ecotect, the Windows are in the correct position; the doors are not in the right place. I have the opening in the wall and the door that does not match.
As a result, even the related wall have an error and looks transparent.
Archicad 16 ita; P i7 win 7, 6gb ram; asus n56v, win 8, 8gb ram
2 REPLIES 2
You should probably report this to your local reseller, along with the file, and they will forward it to Graphisoft, it they cannot tell you anything after checking the file.
It may be an error in the translation to the gbxml fomat, but they will know only after receiving the file from you.
People on this forum may not be of much help in this specific case.
Laszlo Nagy, Lead Moderator, Community Admin
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
minox
After many test I think the problem is in the door sill elevation. If the sill elevation is zero the problem is present. If I set the sill elevation to 0.01 the export is correct.
