Ecodesigner Beta forum
Zone Boundaries and EcoDesigner Star
pallsopp42
In order to accurately represent foundation and slab conditions I have an insulated stem wall beginning at Project zero and an insulated slab abutting it also at Project zero.
Currently the auto-perimeter Zone command returns a zone that is tied to the stem wall and slab "joint" although both are set at Project Zero. This offsets sets the zone back from the walls by about 100mm (based on the edge conditions I'm designing for) and thus in Ecodesigner Star walls simply disappear and the zones have extensive "uncovered areas"
Has anyone else run into this kind of problem? I guess I could go around and set all zones manually but that could also pose problems as a zone will extend beyond the dimensions of some slabs because of the perimeter stem wall foundation situation.
0 REPLIES 0
