I mostly have a fix for proper MVO display for Doors and Windows. There is an error someplace in the Graphisoft system that returns the exact same value for Full, and Simplified with sash. Both return 6, but Simplified with sash should return 8 and full should return 6. The values are set correctly in their object DWS_MMVOSettings_USA.gsm but it is not transmitting properly.
You will need to select your translations for the old Detailed, Medium, and Simple. Below are the codes and the correct lookup. I translate to my needs rather than rewriting all the code at this point for the new options. If you put a line in your master script: !DWS_MVOSettings_USA then highlight and click on the </> icon to open the object, you can test various options and then look back at the parameter list to see the number that is set.
! iDWDet2D, MVODetlevel2D
WIN2D_1LIN = 1
WIN2D_2LIN = 2
WIN2D_2LINFRAMES = 3
WIN2D_GLASS1LIN_NOSASH = 4
WIN2D_GLASS1LIN_SASH_NOACC = 8
WIN2D_GLASS1LIN_SASH = 5
WIN2D_GLASS1LIN_REBATE = 6
WIN2D_GLASS2LIN_REBATE = 7
if P_Det_Level = "by MVO" then
MVO_2DDetail = 0
_bSuccess = LIBRARYGLOBAL("DWS_MVOSettings_USA", "iDoor2DDetlevel", MVO_2DDetail)
if _bSuccess > 0 then
if MVO_2DDetail = 11 then
Det_Level = "Detailed"
No_Trim = 0
endif
if MVO_2DDetail = 10 then
Det_Level = "Detailed" !my medium
No_Trim = 1
endif
if MVO_2DDetail = 9 or MVO_2DDetail = 1 then
Det_Level = "Simple"
No_Trim = 0
endif
else
No_Trim = 0
endif
endif
For windows, which are not completely functional as described above, the lookup is similar, but a different parameter is checked.
MVO_2DDetail = 0
_bSuccess = LIBRARYGLOBAL("DWS_MVOSettings_USA", "iWindow2DDetlevel", MVO_2DDetail)
if MVO_2DDetail = 6 then
No_Trim = 0
endif
if MVO_2DDetail = 8 then
No_Trim = 1
endif
if MVO_2DDetail = 1 then
No_Trim = 0
endif
else
No_Trim = 0
endif
endif
I hope this helps. Grapisoft, please update your documentation immediately (you have had a year) and also fix the window error.
Many Thanks, JP
John Peterson, AIA
Dalgliesh Gilpin Paxton Architects
Archicad 7-21 US
PC and iMac
