2020-11-30 10:34 AM - last edited on 2021-09-15 09:29 AM by Noemi Balogh
Solved! Go to Solution.
2020-12-17 08:46 AM
2020-11-30 11:22 AM
2020-12-01 09:19 AM
2020-12-01 09:50 AM
2020-12-01 09:56 AM
2020-12-01 10:16 AM
SandraGS wrote:You have to edit the generated 3D script to use parameters instead of hard-coded string attributes. You might have to add more parameters if the morph has many surfaces.
Alright.
So what can i do with it now? Can it be fixed somehow? Do I just need to wait?
2020-12-01 10:40 AM
2020-12-02 02:45 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2020-12-02 06:04 PM
SandraGS wrote:The 3D script contains statements like
This is very new to me, so can you maybe show me an example? Of where i need to change it?
Its a lot in the script, and i dont know where to start or what to remove or anything.
r = REQUEST{2} ("Building_Material_info", "Water", "gs_bmat_surface", bms_47) set building_material "Water", 104, -1 material "Wood - Pine Grained Horizontal"In this situation building_material only defines the cut surface and fill of the object. The materials are the outer surfaces. Count the number of different strings for each type.
material MainBoxMaterial
2020-12-14 10:16 AM
