Jochen Suehlo
GLOB_ELEM_TYPE of Wallend
GLOB_ELEM_TYPE of Wallend gives back the VALUE 3 in a label which is the same as "Window".
How can I label a wallend as wallend like the Text/Autotext label does?
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
1 Solution
runxel
I was hoping for using ANCESTRY_INFO, but that does not work for the labeled elements, just for the element itself....
But I think what you can do instead is to check for the presence of "AC_fit_to_wall_height", since that comes with the subtype ("blue parameter") and is not available in windows.
Or you just check the name of the labeled element.
Go to post
3 Replies 3
Ricardo Lopez
Hi @Jochen Suehlo
Apparently there is no specific GLOB_ELEM_TYPE for Wallend (GDL Reference Guide p 344).
Ricardo López, M. Arch.
runxel
Jochen Suehlo
Thank You, Runxel.
"AC_fit_to_wall_height" works well.
I have initialised this variable with - 1000 m, so that it should fit in most 🙂 cases.
