GDL
How to compare a positive and negative value and determine which is larger
Jarrod Phillips
Hi All,
As the topic suggests, is there a way to compare two values, one being a positive value and the other a negative, and determine which is the larger value? For example, I have two values, the first is 589 and the second is -788. I want to compare the values irrespective of whether it is positive or negative, in this instance the -788 is the larger value.
OR
Is there a GDL command to easily swap a value from being negative to positive?
Thanks in advance!
Regards,
Jarrod
BIM Manager | Graduate of Architecture
Fulton Trotter Architects - Sydney, Australia
Archicad 15 - 27
Miha Nahtigal
ABS (x)
https://gdl.graphisoft.com/reference-guide/functions
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
Miha Nahtigal
ABS (x)
Perfect, thanks @Miha Nahtigal
Archicad 15 - 27
