LeeJaeYoung
I'm trying to place a marker in the direction the door opens, is there a way to tell them apart? I
I would be grateful if you could tell me where to look.
AC27 on window 11
2 Solutions
AllanP
https://gdl.graphisoft.com/reference-guide/doors-and-windows
that is how direction is determined.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
Go to post
LeeJaeYoung
That's what I'm looking for.
Label for opening codes in GDL - Graphisoft Community
Today, I have to thank Berry. ^^
AC27 on window 11
Go to post
5 Replies 5
AllanP
LeeJaeYoung
text2 0,1.8,windo_reveal_side
text2 0,0.9,symb_mirrored
text2 0,0.3,symb_rotangle
in Door
in Marker
What you've told me can't be applied to markers.
I now want to position the markers.
However, I am not getting the direction right.
AC27 on window 11
Are you trying to script your own marker in the door object (i.e. just text and a circle in the door object)?
Or are you just trying to script your own marker that you can use with a door?
If you use the default marker objects they automatically position with the door swing with an option to flip if you want to.
LeeJaeYoung
AC27 on window 11
LeeJaeYoung
I am coding in GDL.
I think I found what I was looking for in your previous answer.
thank you
But I don't know if it's right.
Later, when my skills improve a lot, I will have to study Marker in depth.
And in Korea, the form used is different.
So I am studying GDL. So you can use it in practice.
It would be more helpful if you showed me the code for this part you said, but I will study more later. ^^
AC27 on window 11
