GDL Enthusiast
IF THEN Statements
If I write and IF THEN statement, the editor sometimes returns an error if I add an ENDIF on the next line. Most of the time it seems to run without error if I don't even add the ENDIF statement when creating a list of logic.
The editor seems to like ENDIF after a series of parameters e.g:
IF list = 0 THEN
item = 1
method = 2
ENDIF
The Editor has no fault with no ENDIF after the following logic:
IF list = 0 THEN item = 0
IF list = 1 THEN item = 1
Is there a clue as to when an ENDIF is required?
Many thanks, Matt
1 Solution
When the IF, THEN, command is all on the same line, you do not need the ENDIF (I still put it there anyway).
When the command is on a separate line, you must use ENDIF.
Go to post
3 Replies 3
A_ Smith
if condition has only one statement and (as Barry mentioned) then is on the same line, you don't need endif
AC 22, 24 | Win 10
GDL Enthusiast
That is helpful. It was one of those unknowns that is very pleasing to have a definitive answer to.
Thank you both Barry and A_Smith for your responses!
