Libpack and folder/file structure (not reading the translation)
I am trying to uderstand how the folder structure translation works. I have created a dummy library with 3 files. All what I need is the folder/file structure change, so I do not need now *.po files, just pathNameTable*.json. I did only INT for the sandboxing.
I cannot get it to work, probably some silly mistake.
Loading this folder as a libpack does load it straight without translating the path.
Can anyone help with it? Please
12 Replies 12
There is instruction, what i miss here - is something I am trying to do myself: a sandbox library that works, and can be edited just to see how the changes apply.
Create a New .libpack from Scratch/Upgrade .lcf to .libpack | GRAPHISOFT GDL Center
In the end of the day we both probably need to update the already done libraries to libpack mode (for 28+ versions) and keep the sole lcf for the lower versions, with as small changes as possible to reduce housekeeping.
ZsuzsannaB
I have uploaded the working version of your sandbox in my previous reply.
If you have any exact questions or need clarification regarding the process explained in the documentation, I am happy to help.
Wishing you good luck,
Zsuzsi
Thanks a lot,
I missed that in the first read  😞
Funny when I added that mysefl it did not work
And as I see the whole guid part is not actually needed, that's easier 🙂 wrong assumption
I got it working with VELUX library as a folder, but still cannot do .libpack since objects are password protected in lcf
(https://community.graphisoft.com/t5/GDL/LP-XMLConverter-Libpacks-and-password-protected-objects/m-p/...)
