GDL
Light MVO in GDL
vfrontiers
I am trying to use the MVO for lights inside my GDL SCRIPT...
I cannot find the actual GLOB VARIABLE that would reflect the MVO selection...
I see others that use the global variable   GLOB_MVO_STAIR....  for example....
But don't se any for LIGHTS or ELEC...
I tried to REVERSE ENGINEER an existing light, but GS GDL scripts go 9 ways to Sunday to do the simplest things!  So I could not follow...
Any assistance would be appreciated!!!
Thanks
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
2 REPLIES 2
runxel
Hero
I guess you mean these three bad boys?
This is how it's done:
lamp_symb = 0
rrr = LIBRARYGLOBAL("LibraryGlobals13", "iLSymbol", lamp_symb)
if rrr and lamp_symb then
  ! your code here
endif
Request the info from the "LibraryGlobals13" GDL (which constitutes the MVO panel).
The answer you can get is either 1, 2, or 3.
I think you'll figure it out from here on 😉
Domagoj Lukinic
