GDL
SOLVED!
Problems with TEXT2
Otavio Augusto
Hello, I'm trying to create an electrical object symbol following the standards of our office, but when writing the 2D drawing script, the TEXT2 command is not respecting the created DEFINE STYLE directive. Does anyone have an idea of why this might be happening?
It's a very simple drawing that is almost ready, I just need to get the text to respect the created style so that the text stays within the 2D drawing.
Below is the line of code referring to the problem with TEXT2 and DEFINE STYLE.
!TESTE FORMA iExample = 4 | ALGUM ERRO EM DEFINE STYLE
if iExample = 4 then
	circle2 0, 0, radius2
	circle2 0, 0, radius1
	HOTARC2 0, 0, radius2, 0, 360
	DEFINE STYLE "3" "Calibri", 0.5, 5, 0
	text2{3} 0,0, "TV"
endif
i'm sorry if i didn't post in the right forum.
1 ACCEPTED SOLUTION
Solution
Kevin Lee
DEFINE STYLE 'labeltext' "Calibri",0.5,5,0
SET STYLE 'labeltext'
text2 0,0, "TV"
The above define style and set style will work but i recommend below:
TEXT_SIZE = TEXT_SIZE *(100/GLOB_SCALE).   : redefine the text size to suit the drawing scale
DEFINE STYLE "AAA" fonttype, TEXT_SIZE, 1, 0
SET STYLE "AAA"
TEXT2 0, 0, "TV"
*Recommend adding the parameters over set font type and size in the script. see the sample below.
Kevin Lee | Director of Technology | BIM
TZG Architects
ARCHICAD 27 | GDL | Rhino.GH | Solibri | Twinmotion
Mac Studio-M2 24‑core CPU | 60‑core GPU | 128GB memory
5 REPLIES 5
LeeJaeYoung
DEFINE STYLE "3" "맑은 고딕", 0.5, 5, 0
style "3"
text2 0,0, "가자TV"
You just defined the font, but didn't set it up for use. And text{2} is a command I don't know, so I tested it by changing it.
AC27 on window 11
I try to reload it to reflect the changes I made. There are times when you can't do this...
AC27 on window 11
Solution
Kevin Lee
text2 0,0, "TV"
SET STYLE "AAA"
TEXT2 0, 0, "TV"
TZG Architects
yessss, thanks so much!
how could i miss it...
but the obvious is only obvious when you know it right? lol
Obviously. 🤣
