Lingwisyer
Guru
Railing - Diagonal Rails
Hi all,
How would you go about creating diagonal rails within your handrail? I am wanting to create some cross braces and thought I could use a custom panel, but it doesn't stretch to fit...
The distance between posts varies at different points around the building, so is there a way to make them stretch to fit?
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
1 Solution
This is what you will need to do to create a X panel.
The 'Built-in Panel' object is not in the library as it is part of the Archicad program itself.
So to open it, create a railing using it, select it then CTRL+SHIFT+O.
Close all the other objects that open as they aren't needed.
'SAVE AS' with a new name - something like 'Cross panel'.
Create a new length parameter called ... rail_hgt
In the 3D script find and comment out this section (starting at line 263).
!!!!				group lowergroup
!!!!					for nSide = 1 to nTransformedPoly
!!!!						if segmentCutFlag[nSide] then
!!!!							_cutangle = segmentCutAngle[nSide]
!!!!						else
!!!!							_cutangle = 0
!!!!							if segmentContinueFlag[nSide] then
!!!!								if segmentSideFlag[nSide] = SIDE_END then _cutangle = _cutright
!!!!								if segmentSideFlag[nSide] = SIDE_START then _cutangle = _cutleft
!!!!							endif
!!!!						endif
!!!!						put transformedPoly[nSide][1], transformedPoly[nSide][2],
!!!!							_cutangle, transformedPoly[nSide][TRPOLY_STATUS], _matPanel
!!!!					next nSide
!!!!					cprism_{2} _matPanel, _matPanel, _matPanel,
!!!!						nTransformedPoly, ac_panelThickness / 2,
!!!!						get(nsp - 2), -1, _matPanel
!!!!					gosub "flushBuffer"
!!!!				endgroup
!!!!				group uppergroup
!!!!						else
!!!!							_cutangle = 0
!!!!							endif
!!!!						endif
!!!!						put transformedPoly[nSide][1], transformedPoly[nSide][2],	! [nSide][3] should be all the same
!!!!							-_cutangle, transformedPoly[nSide][TRPOLY_STATUS], _matPanel
!!!!					next nSide
!!!!					addz ac_panelThickness
!!!!					mulz -1
!!!!					del 2
!!!!				endgroup
Directly after that add this ...
!!!The geometry for all the corner points
horiz_panel = (transformedPoly[2][1]-transformedPoly[1][1])*COS(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
vert_panel = (transformedPoly[3][2]-transformedPoly[2][2])/COS(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
end_rise = (transformedPoly[2][1]-transformedPoly[1][1])*SIN(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
cross_angle = ATN((vert_panel+end_rise)/horiz_panel)
panel_cross_angle_1 = cross_angle-panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]
cross_x_rad_1 = (rail_hgt*0.5)/SIN(panel_cross_angle_1)
cross_y_rad_1 = (rail_hgt*0.5)/SIN(90-panel_cross_angle_1-panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
y_reduction_1 = cross_y_rad_1-(cross_y_rad_1*COS(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]))
if panelSegmentData[iSegment][SEGMENT_SLOPEANGLE] <> 0 then
	x_reduction_1 = y_reduction_1/TAN(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]*0.5)
else
	x_reduction_1 = 0
endif
panel_cross_angle_2 = ATN((vert_panel-end_rise)/horiz_panel)+panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]
cross_x_rad_2 = (rail_hgt*0.5)/SIN(panel_cross_angle_2)
cross_y_rad_2 = (rail_hgt*0.5)/COS(panel_cross_angle_2-panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
y_reduction_2 = cross_y_rad_2-(cross_y_rad_2*COS(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]))
	x_reduction_2 = y_reduction_2/TAN(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]*0.5)
else
	x_reduction_2 = 0
endif
				group lowergroup
						put transformedPoly[1][1], transformedPoly[1][2],
							0, 15, _matPanel
						put transformedPoly[1][1]+cross_x_rad_1, transformedPoly[1][2],
							0, 15, _matPanel
						put transformedPoly[3][1]-x_reduction_1, transformedPoly[3][2]-cross_y_rad_1+y_reduction_1,
							0, 15, _matPanel
						put transformedPoly[3][1], transformedPoly[3][2],
							0, 15, _matPanel
						put transformedPoly[3][1]-cross_x_rad_1, transformedPoly[3][2],
							0, 15, _matPanel
						put transformedPoly[1][1]+x_reduction_1, transformedPoly[1][2]+cross_y_rad_1-y_reduction_1,
							0, 15, _matPanel
							0, 15, _matPanel
						7, ac_panelThickness / 2,
					gosub "flushBuffer"
						put transformedPoly[2][1], transformedPoly[2][2],
							0, 15, _matPanel
						put transformedPoly[2][1]+x_reduction_2, transformedPoly[2][2]+cross_y_rad_2-y_reduction_2,
							0, 15, _matPanel
						put transformedPoly[4][1]+cross_x_rad_2, transformedPoly[4][2],
							0, 15, _matPanel
						put transformedPoly[4][1], transformedPoly[4][2],
							0, 15, _matPanel
						put transformedPoly[4][1]-x_reduction_2, transformedPoly[4][2]-cross_y_rad_2+y_reduction_2,
							0, 15, _matPanel
						put transformedPoly[2][1]-cross_x_rad_2, transformedPoly[2][2],
							0, 15, _matPanel
							0, 15, _matPanel
					gosub "flushBuffer"
				endgroup
				group uppergroup
					mulz -1
							_cutangle, 15, _matPanel
					gosub "flushBuffer"
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
					gosub "flushBuffer"
					del 2
				endgroup
In the interface script (edit: not parameter script) find these line starting at line 62 and comment them out.
!!!!	_yCurr = _pageStartY + 37
!!!!	ui_infield{3} ac_panelThickness, _x2, _yCurr, _infWidth, _infHeight
Then add ...
	ui_infield{3} ac_panelThickness, _x2, _yCurr, _infWidth, _infHeight UI_TOOLTIP "Rail Width"
	ui_infield{3} rail_hgt, 380, 130, 50, _infHeight UI_TOOLTIP "Rail Height"
Now re-save and you should find it available as a panel type in your railing.
Of course you will need this in your loaded library or your embedded library.
I can't guarantee it will work in all situations (I haven't tried leaning the railing on an angle), but it seems to work for flat and rising (stair) railings.
Go to post
21 Replies 21
Lingwisyer
Guru
No ideas? Looks like I might need to resort to scripting one... T_T
Yes, you would probably have to script it so that it will stretch properly. If you model it and save it as a Railing Panel, it will be static, it will probably not stretch (I think, I have not tried this).
I would try to create a custom Railing Panel, not a custom Post.
I just tried saving a custom railing panel.
Seems you will have to get the exact size for both horizontal and raking railings and also any different heights and widths of panels..
The custom panel does not stretch to suit the actual panel extents.
Or you need to figure out the script of a panel object and base your diagonals on the extents of the panel.
Just had a look at the "Built-in Panel' and typically the script is very difficult to follow.
It seems there is more to this basic object than just a flat panel with 4 bounding corner points.
I have managed to figure out the node co-ordinates for the corners of the panel in the built-in panel macro.
These are PUT in the script just before the CPRISM{2} that creates the panel (actually there are 2 half thickness panels - not sure why exactly).
In the attached image you can see I have spheres at these points.
Then with a bit of maths I have calculated the railing angle and some x and y offsets that would be required for the nodes of a diagonal prism.
I have just added some lines at this point to get the width of the diagonal rail.
But it doesn't work when the railing is angled up a stair.
It seems I need to take into account the ROT of the panel in another way other than just calculating the angle of the railing.
So I am sure something is possible.
I will have more of a play later when I get some more free time.
I have moved this entire post to Libraries/GDL section, as that is really what it has turned into.
It is possible to create a stretchy X panel.
Unfortunately I can not post the object here as I have simply modified the 'Built-in Panel' object by Graphisoft, and licensing requirements say I can not distribute a modified object.
Read here ...
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=47320
However I can give instructions on how to modify the object for your own use.
So stay tuned.
!!!!						else
!!!!							_cutangle = 0
!!!!							endif
!!!!						endif
!!!!					next nSide
!!!!				endgroup
!!!!						else
!!!!							_cutangle = 0
!!!!							endif
!!!!						endif
!!!!					next nSide
!!!!					mulz -1
!!!!					del 2
!!!!				endgroup
else
	x_reduction_1 = 0
endif
else
	x_reduction_2 = 0
endif
				group lowergroup
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
					gosub "flushBuffer"
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
					gosub "flushBuffer"
				endgroup
				group uppergroup
					mulz -1
					gosub "flushBuffer"
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
							0, 15, _matPanel
					gosub "flushBuffer"
					del 2
				endgroup
Then add ...
Lingwisyer
Guru
Wow, thanks Barry.
I had a separate post within the GDL sub-forum regarding programming a custom panel, so it should probably be merged or removed...
Ling.
Lingwisyer
Guru
In the parameter script find these line starting at line 62 and comment them out.
Could not find this line in my Parameter Script, there was actually very little in it at all... Found it in the Interface Script which I'm assuming is what you meant given the _yCurr.
Yes, sorry I meant the interface script.
I think it should also be...
ui_infield{3} rail_hgt, 380, 130, 50, _infHeight UI_TOOLTIP "Rail Height"]
I think the formatting got messed up - seems it gets messed up when I tag it as code.
At least it is for me on this machine - not my regular machine.
It is just adding the rail height parameter and adding some tool tips.
I will fix the original post.
