Miko
SLAB_SKINS_BMAT_NAMES not working correctly when printing 9th < skin
In a label this SLAB_SKINS_BMAT_NAMES parameter "breaks" when listing the 8 or 9th skin (and further skins). Works as expected in 7 or fewer. Tried it with a very dumbed down version of my label, simple rows with: text2 0, "manuallychangedposition",SLAB_SKINS_BMAT_NAMES [manually changed id][1]. If a slab had 4 skins and I wanted to print the 7th skin, it printed nothing, which is correct, no 7th skin, but if i wanted to print the 9th skin the label started to look like a dot - missing object, even if i added lower skins for the function to read, once i added the 9th skin, it always showed only a dot. Unless the slab had acces to the 9th skin, in which case it broke on the 10th skin.
12 Replies 12
Lingwisyer
Guru
Superseded, though neither of the those requests work outside of labels...
runxel
Well to be fair, neither of the "old" Globals did either... 🤔
But yeah, it would be cool to just request all the data in the project from GDL without limitations.
Lingwisyer
Guru
Really? I was sure I had used WALL_SKINS_NUMBER in 3D...
