yesterday
I am hoping to reference the Sea Level height of the project in the elevation and section views. I have tried and searched without success. The best I have is
ObjectHt = int(SYMB_POS_Y*1000)
This returns the height of the object in the Y-axis relative to project zero. Is there any way to find the Sea level, 1st or 2nd Reference levels in elevation and section views?
Many thanks, Matt
Solved! Go to Solution.
yesterday - last edited yesterday
Could you REQUEST ( "REFERENCE_LEVEL_DATA", "", name1, elev1, name2, elev2, name3, elev3, name4, elev4 )? 4 should be sea level.
Do note that the value is in meters and is the distance below Project Zero to Sea Level hence would typically be negative. So for your sea_level_height, you would minus elev4 * 1000
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Ling.
10 hours ago
Hi Ling,
Thank you for your response, it prompted me to look at that script and I realised I had used SYMB_POS_Z. I would have given up, but thanks to you it is solved, so appreciated! Wishing you all the best, Matt
