Bruce
Surface name of fill
Is there a way to extract / query the name of the Surface used in a Surface Fill?  One can query the fill name or BMAT name of all fill types (Drafting, Cut, Cover, Building Material), but one cannot query the Surface of a Surface type fill.
Any clues?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
9 Replies 9
Diego Rojas
It would be great to know how to do this. There are so many parameters and pieces of information that would be highly useful to access in Archicad, but at times, Archicad does not allow access to them through standard Archicad knowledge.
AC-10 to 28 forward
Apple IOS
Aaron Bourgoin
have you tried Tapir for this? require Rhino and Grasshopper, but I think they have nodes that would query this.
having said that I expect your doing something in GDL.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Hi Bruce, not sure if it may be related to what you are trying to achieve... sound kind of the opposite approach. I have developed a GDL tool to generate keynotes from any project surface, see the demo in the video attached. I am requesting the textures used by each surface selected by the user and this generated in line definitions for image fills to recreate the legend.
www.graphisoft.com/en-gb/partner-solutions/airc-digital-openbim-services/ co-founder /Operations Director /BIM Lead @ www.airc.digital ltd ™
M Architecture & Urbanism
Archicad 29 ARM, MacBook Pro M3 Max 128Gb, macOS Tahoe.
Bruce
Looks good Jaime.  However, the usage I'm after is for when surface fills are used in details / worksheets.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
kuvbur
Did you try REQUEST gs_mat_fill_ind?
bmat = 5 !Bmat index
mat = 0 : gs_mat_fill_ind = 0 : gs_mat_fill_name = ""
n = REQUEST{2} ("Building_Material_info", bmat, "gs_bmat_surface", mat)
n = REQUEST{2} ("Material_info", mat, "gs_mat_fill_ind", gs_mat_fill_ind)
n = REQUEST ("Name_of_fill", gs_mat_fill_ind, gs_mat_fill_name)
text2 0, 0, gs_mat_fill_name
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
Bruce
Yes.  That will return the fill name.  I'm after the surface name.
n = REQUEST{2}("MATERIAL_INFO", name_or_index, param_name, value_or_values) will return what I'm after IF I can retrieve the "name_or_index" of the fill to which the label is attached...which I don't think is currently possible in GDL.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
kuvbur
Could you show me a screenshot of the information you would like to receive?
Bruce
Attached
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Michael W
It'd be great to expand the Global Variables for Fill parameters to include surfaces. We have 'FILL_BMAT_NAME' & 'FILL_BMAT'. We need 'FILL_SURF' and 'FILL_SURF_NAME'
13th Gen Intel(R) Core(TM) i9-13900HX 2.20 GHz, 64 GB RAM, Nvidia GeForce 4050 Laptop GPU 32GB, 2 TB PCIe 4.0 NVMe SSD
1X32" (3840x2160), WIN11 PRO ENG, AC9-AC27
