LeeJaeYoung
The title indicates that the variable value is blank.
if "<Dong Name>" = "" then
     text2 0,0,1
else
     text2 0,0,2
endif
Number 2 appears. Even if you use "#", you get the same result.
How do I know if the space is blank?
AC27 on window 11
1 Solution
As far as I know, GDL can not read the value of the Project Info variables
That is probably why you can't determine if it is empty or not.
All GDL can do is display the value.
It will be blank if it is empty.
Go to post
LeeJaeYoung
Yes, you have to turn it on/off as an option.
AC27 on window 11
