GDL Enthusiast
UI Header Removal
Is it possible to turn off the User Interface Header (example from standard AC Bed below)?
If I deselect Hierarchical pages, the header remains present but with "Custom Settings" as default header.
Many thanks, Matt
1 Solution
runxel
Of course is this possible. You need the following things to be done for that:
1. Don't use this button (hierarchical pages):
2. Use hideparameter all "A", "B", "ZZYZX in the Parameter script (This will force hide the "all params" page).
Go to post
7 Replies 7
Lingwisyer
Guru
I assume your other page is the All Parameters page? What happens if you hide your paramters? This will removed that page, though I am unsure whether it will hide the header, or just grey out the button to change page...
Ling.
runxel
GDL Enthusiast
Hi Runxel and Ling,
Thank you both for responding! I have tried hideparameter all "A", "B", "ZZYZX without success. In my searching of other objects, I can't seem to find one that successfully hides the User Interface Header bar. It leads me to think it is not possible to hide. Thank you for your help! Wishing you both the best, from Matt
Jochen Suehlo
Runxel's advise works well. But do not forget to deacticate the "Hierarchical Pages" Button.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
JudsonCrane
It worked for me, Thank you so much.
BTW: with  disabling hierarchical pages, and do hideparameter all ...[,"A","B", "ZZYZX"] - optional unhidden :
You can have more space in height in the UI by aprox 20 points...it can be used with -Y values in the coords of the UI element.
GDL Enthusiast
Thank you so much, I revisited the code and it works this time, you are all super thank you!!! Best regards, Matt
