2024-08-02 09:57 PM
Team:
I do not find any conversation on this issue so it must be something I am doing wrong.
Where do I turn off the "Blue Background" on the 3D window, Also in Favors Pallett?
Solved! Go to Solution.
2024-08-03 04:20 PM
Yes that is the Physical Based Rendering sky.
You have to turn PBR off in Work Environment > More Option > Experimental Features as runxel mentioned.
2024-08-03 05:14 AM - edited 2024-08-03 05:15 AM
The 3d styles palette. Can change backgrounds, shading type, shadow and line type. Bottom right corner of screen.
2024-08-03 02:19 PM
However this could also be due to the "experimental" PBR view being set to "on" in the work environment.
2024-08-03 04:20 PM
2024-08-05 07:27 PM
Yes!! That was the problem. I turn off the:
Work Environment > More Options > EXPERIMENTAL FEATURES
Enable Property Update in Hotlink Modules
Thank you very much
