Graphisoft Technology Preview Program 2024
Curve angular stretch disorder
Hi all,
As illustrated in this short video & as the title explains, pls check this issue, thanks.
Note: I use the latest update for 28 TP.
AC 27 INT 5060/WIN 11
Gerald Hoffman
I think you will find that if you select only 1 curved section at a time it will work. When 2 are selected at the same time it behaves this way.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Hi @Gerald Hoffman,
Yes, you're right.
When I select more than one curve that activates the (Move node) option, despite at the same case for walls it behaves normally, I hope it's fixed later.
