Graphisoft Technology Preview Program 2024
Feature request Hotlink
bimdo
Hi there, thank you for the new possibilites with hotlinks in Archicad 28. During testing some inputs from my side:
  • There should be a connected manager-file which solves the topics attributes, element properties and translators. Change this motherfile and all other files change too or have to accept the change.
  • Hotlinks working at the moment like clones, there should be some attributes we can change. For example door numbers or room numbers. On the other hand we often have buildings with exact the same floorplan, but the rooms are a bit higher, for this situation it would be great to change all z-parameters, but not x/y (More detailed with window-settings etc.). Then we’ve situation where the only difference is one window… why not having hotlinks with more flexibility?
0 REPLIES 0
