Hi there, thank you for the updated Archicad 28. Some inputs from my side:
- We need more detailed options for the Authorisations… it’s not enough to say, someone can’t add a layout. We want to say, someone only can work in this layer and only see this part of the navigator.
- We need setups for the properties, that we can freeze and open different properties, that not each user can change them.
- A viewer to comment and add/ change properties would be nice. Then some users only have to open the Bimcloud and don't need Archicad-Skills.
- A viewer to connect different ifc’s and pdf’s like in BIMx but not closed, would be great.
- Comments sent from BIM’x should be saved in a database, which can be exported as csv, bcf.
