Graphisoft Technology Preview Program 2024
Feature request connectivity
bimdo
Hi there, thank you for your great work in Archicad 28. During testing some inputs from my side:
  • There should be an option to connect elements together. For example could we solve the problem with the window sill and the window, when we can connect a profil with a window. Then we could model the sill with the profil and each time, when the window is changing the sill is changing too.
  • There should be a way to add properties from zones to a wall and from the wall to the door, because they’re connected.
  • We would like to add plaster or tiles threw the zone stamp as an extra layer to the wall, otherwise we’ve to split walls or model with different layers
2 REPLIES 2
Have you trier the 'Interior Wizard'?
You will need to load the Goodies add-on if you haven't already.
I am not saying it is a great add-on, but may do what you want.
Botonis
 A more advanced addon for wall coverings by @BerndSchwarzenbacher is this one:
https://archi-xt.com/add-ons/room-coverings/
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
