Graphisoft Technology Preview Program 2024
Feature request facade tool
bimdo
Hi there, thank you for the improvments in Archicad 28. During testing some inputs from my side:
  • The profiles around the façade have only one standard-parameter, we need one parameter for each side of the façade. Of course we can change them manually, but with the next change, all this settings are missing.
  • The perimeter line should not be in the center of the profile, it should be around the hole façade, when you do that, then you’ve missing fixpoints for your measurements.
  • The windows and door libraries should be available in the façade too.
  • We need more individual settings without manually changes (for example it should be possible to setup different element-id’s for each element), when we change things manually, everything will be deleted with the next big change.
0 REPLIES 0
