Saturday
Hi there, thank you for the new Archicad 28. During testing some inputs from my side:
Labels
Section-markers & co.
The possibility to create a 3D-script would be enough;) the rest we can script ourselves.
Sunday
That's what we've been imagining for many versions too, but it seems to be a fundamentally different approach for the cutting tool and it would mean a complete overhaul of the tool (everything should be backwards compatible...). It's questionable whether that will (ever) happen or whether "third parties" will do something via the API (at least).
Sunday
A 3D script is a good idea, but Graphisoft needs to concentrate on completely thinking through a tool and, above all, programming it, since the vast majority of users actually cannot and will not script.
Monday - last edited Monday
@bimdo schrieb:Section-markers & co.
- They should have a 3d representation too, otherwise we’ve to place 3D boxes in the model separately to show the position in the model too.
I see no harm in creating additional 3D Geometry. You also want/need coordination objects for your IFC collaboration - as long as those geometries are distinctly classified, and imediatly recognisable as such.
More IFC export control over 2D Elements would be appreciated though.
