Graphisoft Technology Preview Program 2024
Feature request labels & section markers
bimdo
Hi there, thank you for the new Archicad 28. During testing some inputs from my side:
Labels
  • It should be possible to create labels with information from to elements. Sometimes we’ve to model things with two elements, want to see the description on the plan as one list.
  • Labels should have a 3D-element too and a connection in 3D too, at the moment we’ve to place 3D boxes separately to show the detail-position in the model.
Section-markers & co.
  • They should have a 3d representation too, otherwise we’ve to place 3D boxes in the model separately to show the position in the model too.
The possibility to create a 3D-script would be enough;) the rest we can script ourselves.
3 REPLIES 3
szab
That's what we've been imagining for many versions too, but it seems to be a fundamentally different approach for the cutting tool and it would mean a complete overhaul of the tool (everything should be backwards compatible...). It's questionable whether that will (ever) happen or whether "third parties" will do something via the API (at least).
Szabolcs Sóti - CEO - www.bim-visual.com
AMD Ryzen 7945HX - NVIDIA RTX 4080 12GB - 64GB RAM - WIN 11 Pro - AC5-AC2X
szab
A 3D script is a good idea, but Graphisoft needs to concentrate on completely thinking through a tool and, above all, programming it, since the vast majority of users actually cannot and will not script.
Franz Sdoutz
I see no harm in creating additional 3D Geometry. You also want/need coordination objects for your IFC collaboration - as long as those geometries are distinctly classified, and imediatly recognisable as such.
More IFC export control over 2D Elements would be appreciated though.
