Hi there, thank you for the updated Archicad 28, some inputs from my side:
- In graphical overrides and properties aren’t always all parameters available like in the schedules or in the ifc translator. (for example all GDL-parameters)
- Properties should be available for composites and folders of composites, that make for many information more sense, then add them all on each element. That means, that we can group composites and add information to the group. On the other hand we would like to add information to a composite directly and to the building material in the settings of the composite. There are some information which are related to a specific layer in a wall, but we don't want to create a new building material each time. When we would have the opportunity to add building materials in the settings of the composites too, then we could solve that.
- There should be an option to connect properties between building materials and elements, so that the element can ask for the used properties in the building materials and the building material expressions should ask for the element-properties
- More options to format text in the properties, really important is “line break”, because when we schedule the data....
- We need a better manager with a timeline too, that we can hide properties, before they’re relevant and on the other side we want to freeze them, that they’re not changeable anymore or only for specific user.
