Hi there, thank you for the new improvments in Archicad 28. After testing some feature request from my side:
- The quantities of composite elements aren’t in the structure available (for example in Speckle), we need the quantities of each layer in Speckle too.
- The element-list only react on the building material ID, but not on an individual property of a building material.
- They should be live connected to the 3d-model for a more visual control.
- Colorizing the list and the model is colorized too like in Solibri.
- When you visualize the different parameters in the model, then we should see which wall side Archicad has chosen for the schedule. A great example here is the platform Kabandy, where you see where the area is calculated (which side).
- At the moment there’s no way to schedule slope insulations with different thicknesses at the start and ending point.
- We would like to count wall ends, wall corners, etc., because that's relevant for cost calculations in Switzerland.
- Scheduling roofings is sometimes not that easy, because we model them with different slabs and at the end we need the perimeter of one square and not twelve triangles.
