2 weeks ago
I have made a copy of an object from the furniture libpack. I have made a few adjustments and gave it a new name. I made it into a new libpack. But the object shows it english parameters and custom interface. How do I copy the translation from the original object?
Thanks a lot in advance!
Jeroen
Tuesday
I found it:
-place the desired object in an really empty file. Then save it a a PLA. Open the play en extract the library. The resulting object are permanently translated.
Wednesday
The other way would be to
Place the object in Archicad 28 default template or your custom A28 template
Select the object on plan and use command Open Object, check how 2D of object looks like change 2D pens if they are wrong and save to new Custom Library for A28 objects.
This way you can adjust some parameters to suit and fix them if needed. You might also check if there are Macro linked to the object those Macro files need to be saved for A28 too. Look for CALL " " in 2D and 3D script
macro name is in-between exclamation marks. To open it select the text between exclamation marks and use the same command Open Object, this will open macro. Check its parameters and save as in custom library for A28, not Overwrite them
Very important do not overwrite old objects save them as objects for A28, When you save them in A28 you will not be able to use them in earlier versions of archicad
Archive pla file saving objects sometimes can not find macro files and they are not included so your object without macro will not work.
GDL is not required for that but would be easier if you know the basics.
Good luck
