2024-07-06 12:00 AM
Hi All,
We have introduced a new documentation focused workflow for Keynotes in Archicad 28, to help simplify and consolidate tags and descriptions into one database and palette.
For more information:
https://community.graphisoft.com/t5/Graphisoft-Technology-Preview/Keynotes/ta-p/606482
2024-08-22 07:13 PM
I recently transitioned from CadImage Keynotes to Graphisoft. The process was relatively straightforward, though not entirely seamless. Here’s what I did, and I hope I haven’t missed anything. Since I use a Mac, I had to take a few extra steps:
1. Export your keynotes to Excel. I had over 800 notes.
2. Open the Excel document (I had to open it in Numbers).
3. Before doing anything else, I created a new column A with a sequence number, which helped me shorten the file later.
4. I deleted all the columns except for the key, title, description, and reference.
5. I created a column “C” after the key number column (A) with a formula: IF(B1=B2, "X", "") and dragged it down to the end of the file. This formula searches for duplicate IDs. In CadImage Keynotes, a unique ID is available, so this didn’t seem to be an issue.
6. I copied column C and used “Paste Formula Results” from the edit menu.
7. I scrolled through to find the cells in column B marked with “X” and adjusted the key numbers to ensure there were no duplicates.
8. I sorted the data by column A.
9. Finally, I imported the data into Keynotes.
After that, I had to build the folders and organize all the keys into each folder. It sounds like a lot of work, but since I’ve structured my keynotes using the MasterFormat, it wasn’t too bad. There is a way to create the folders in Excel, but it gets complicated, so I opted to do it manually.
While CadImage Keynotes has some advantages over Graphisoft, I believe the Archicad tool in AC28 is very promising and just needs some refinement.
I also used properties to assign reference numbers to an external FileMaker file, which contains all the technical information for the construction manual.
So far, I’m very happy with the results. Hope this helps you.
2024-08-23 08:01 AM - edited 2024-08-23 08:14 AM
@James B Ok, had escaped me, or some other quantum effect ..
Regardless its lack of expression, schedule, autotext ... integration -
just in graphic terms: What data(formats) are expected to be structured? Tables only? And if so, why doesn't the keynote's table have at least the same functionality as the schedules table?
In other terms: Why aren't keynotes just a different way to place schedule(lists) on plans? (Filter: only display items that have a visible placed anker/marker. (--> See Changes management)
How I would have approached this:
WHY?
2024-08-23 07:12 PM
Hi @Tintifax2
Thanks for the added feedback.
If you have some examples of the type of legend you need to achieve, please share those examples (also on DM if confidential). By using the GDL legend object we could support filtering to visible keys used in Drawing. Which isn't possible with Schedules - and unfortunately not soon either.
We are still investigating ways to connect keynotes (and multiple keynotes) to elements.
2024-08-24 04:12 PM
Thank you for this new tool, many of my clients will like that. Especially for 2D-details it will be a great tool! Some thoughts during testing from my side:
2024-08-26 06:23 PM
Thanks for the feedback.
For the rename, we didn't support double click (rename in place) as we have 2 pieces of data - both ID and Name as the title for folders and keynotes. How would you expect to rename these 2 pieces of data? Just the name? Or somehow both at the same time?
2024-08-28 10:45 AM
Ah, I see your point. It's actually in the layer combination and in the graphical overrides only in the rule settings solved with a double click. Yes, in a first step I wanted to change the name, but I see the logic, it's maybe more a general question:
Navigator: setup below or right click
Layer combination: rename with double click or right click
graphical override combination: rename only in the header
graphical override rule: header or double click
MVD: rename only in the header
renovation filters: rename with a button
pen-set: rename with a button
... and so on.
It's in each tool a bit different, for me that's something I get during supporting Archicad and it would be easier to learn Archicad, when it's similar in many tool-setups (general input). Double click has in my opinion three options: open something, select something in the floor plan or rename and in Keynote = start placing labels. So there's no place to rename, I understand;) Maybe to add some inputs to this start-option:
1) When I double click the keynote, I can directly start... in my opinion I have to check the chosen favorit anyway. I like the idea to double click and start directly, but it would be useful to save the chosen favorit in the keynote, that would speedup the process.
2) I would like to select all keynotes from one type, because if I've to change them (because they're not connected to the settings of the favorit), then I've to open find & select and save for each Keynote-type a favorit with a different layer, that I can choose all of them once.
3) I would like to create a schedule (doesn't work because we've keynotes on worksheets too), which is showing me, where I placed which type of keynote. This helps me to know on which plans I've to change all the keynotes, because of a new favorit.
2024-08-30 09:49 PM
Some ideas:
Folder Naming Options
Rule naming for Keynote Folders: (apply to Key)
Keep it "clean" don't add dashes or dots unless by user.
Folder Sort Options
2024-09-04 11:06 PM
Thanks for the suggested workflow, I was finally able to get my cad image key notes list file imported into AC28 with minor hiccups using your directions.
a month ago
I've spent the last few days using the new keynote feature and I have to concur with a lot of what already been expressed in this forum. Overall it will work sufficiently well enough for more consistent documentation, but the current functionality makes it feel like just another text label. The process to change what is displayed on screen in the keynote requires too many steps. I think it would be easier if the user were able to quickly select whether the key, description or reference is displayed in the keynote, or perhaps even link the information displayed by the key note to the drawing scale. For example on a larger scaled detail view I may prefer to have complete written description available, as opposed to basic keynote. I do agree that the inability to link the keynote directly to the object via the classification / property will lead to user annotation errors. I'm hoping that there will be additional development to the feature over the next development cycle to address comments made across this board.
a month ago
I have an issue where i spent a lot of time typing up keynotes where when i came back to the file the next day all the keynotes were missing and i had to retype them all. Since time was of the essence, i just went back to text labels so I didn't lose them all again.
