List of ongoing improvements in Archicad 28 Technology Preview
[UPDATE] Hello everyone, we would like to update you again the ongoing improvements. Please check out the most updated information in the table below. The most recent changes are listed at the top for your convenience. You can also use the column "Information Last Update" to identify the latest information change.
Meanwhile, our team is working diligently on the remaining items with top priority. If you encounter any unexpected behaviour while using the program, please refer to the list below to check if it has already been reported.
Thank you for staying informed and involved in our Technology Preview Program!
Key Expected Fixed Version Improvement Description Platform Information Last Update Time
DEF-20101 Archicad 28 Hotfix Archicad could crash after finalizing 3D cut planes' positions. Windows & macOS 2024-09-30
DEF-20158 Archicad 28 Update The font "Avenir Next Condensed" was not displayed correctly. Windows 2024-09-30
DEF-19955 Archicad 28 Release "Tags and Labelling" parameters are now turned off in the Window and Door Default Settings (except for CHE version). Windows & macOS 2024-09-30
DEF-19907 Archicad 28 Release There was some missing attributes in the default German library. Windows & macOS 2024-09-30
DEF-19865 Archicad 28 Release Some Door/Window parameters were missing from the Japanese version. Windows & macOS 2024-09-30
DEF-19821 Archicad 28 Release Uninitialized variable in Archicad28 USA Beta. Windows & macOS 2024-09-30
DEF-19820 Archicad 28 Release There was a missing default attribute in Archicad 28 USA Beta. Windows & macOS 2024-09-30
DEF-19747 Archicad 28 Release The default Label type in now Zone Label instead of a simple Label type. Windows & macOS 2024-09-30
DEF-19746 Archicad 28 Release MEPAPI's logical and physical connections were not clearly accessible. Windows & macOS 2024-09-30
DEF-19691 Archicad 28 Release Archicad could crash when an old .xml file was imported to Route Specifications. Windows & macOS 2024-09-30
DEF-19672 Archicad 28 Release MEP elements were difficult to place in a continuous route. Windows & macOS 2024-09-30
DEF-19664 Archicad 28 Release Archicad could crash during the use of Duct Optimizer. Windows & macOS 2024-09-30
DEF-19578 Archicad 28 Release In the MEP System Browser, adding a root by clicking the "+" button no longer leads to crash. Windows & macOS 2024-09-30
DEF-19403 Archicad 28 Release GDL based MEP Elements no longer slow down real-life-size projects. Windows & macOS 2024-09-30
DEF-19389 Archicad 28 Release Changing the geometry method when constructing a Morph no longer leads to crash. Windows & macOS 2024-09-30
DEF-19387 Archicad 28 Release Thermal Bridge Simulation's Temperature Result drawing showed incorrect values.  macOS 2024-09-30
DEF-19057 Archicad 28 Release Tooltips were shifted when using custom display scale. Windows & macOS 2024-09-30
DEF-18970 Archicad 28 Release Pipes or Ducts can now be exported in RVT format Windows 2024-09-30
DEF-18644 Archicad 28 Release L Winder Stair on macOS no longer moves. macOS 2024-09-30
ADD-3 Archicad 28 Release The translations are getting finalized continuously until the Archicad 28 release. Windows & macOS 2024-09-30
DEF-20406 fixed in Technology Preview Update Black squares were shown in font list on macOS 15. macOS 2024-08-15
DEF-20333 fixed in Technology Preview Update Docking the Archicad window to either side of the screen caused the navigator toolbar to disappear on macOS 15. macOS 2024-08-15
DEF-20325 fixed in Technology Preview Update Resizing the Archicad window title bar did not fill the screen properly on macOS 15. macOS 2024-08-15
DEF-20216 fixed in Technology Preview Update Archicad dialogs were shrunk when moved between 2 displays with different scale. Windows 2024-08-15
DEF-20187 fixed in Technology Preview Update Users will be able to sort Keynote Legend fields.
(Important Note: to improve sorting of keynotes and folders, a GDL request change will be made which may break compatibility between the Tech Preview and the Tech Preview Update if a similar legend is created and these requests are used.)
Windows & macOS 2024-08-15
DEF-20132 fixed in Technology Preview Update Back/forward button and shortcut (cmd + Z) did not function after editing a placed route in edit mode. Windows & macOS 2024-08-15
DEF-20120 fixed in Technology Preview Update The “Show Privacy Note” link on the GSReport screen now shows the report correctly. Windows & macOS 2024-08-15
DEF-20119 fixed in Technology Preview Update Archicad could crash because of Autotext on Layouts. Windows & macOS 2024-08-15
DEF-20063 fixed in Technology Preview Update Fallback tooltips now appear correctly at the Learning Content. Windows & macOS 2024-08-15
DEF-20035 fixed in Technology Preview Update There was an error with linkers in case of some API functions. Windows & macOS 2024-08-15
DEF-20025 fixed in Technology Preview Update Chevron icons were missing on macOS 15. macOS 2024-08-15
DEF-19992 fixed in Technology Preview Update Hotkey is now displayed at the Learning Content Tooltips. Windows 2024-08-15
DEF-19991 fixed in Technology Preview Update When Archicad was started on one screen and then moved to another one, Coach Marks appeared on the first screen. Windows & macOS 2024-08-15
DEF-19984 fixed in Technology Preview Update Archicad could crash when opening the downloaded Demo Project in the German version. Windows & macOS 2024-08-15
DEF-19960 fixed in Technology Preview Update Archicad could crash when editing vertical openings. Windows & macOS 2024-08-15
DEF-19900 fixed in Technology Preview Update There is no longer a delay in the GDL Editor's performance. Windows 2024-08-15
DEF-19861 fixed in Technology Preview Update It was difficult to use MEP Route Specifications dialog. Windows & macOS 2024-08-15
DEF-19780 fixed in Technology Preview Update Backward migration from Archicad 28 to Archicad 27 was not working. Windows & macOS 2024-08-15
DEF-19742 fixed in Technology Preview Update Change Tool element favorite icons displayed "###" instead of the actual text in the marker preview. Windows & macOS 2024-08-15
DEF-19736 fixed in Technology Preview Update Keynotes API was not Teamwork-compatible. Windows & macOS 2024-08-15
DEF-19575 fixed in Technology Preview Update The previously viewed coach mark is no longer visible before the new one appears. Windows & macOS 2024-08-15
DEF-19547 fixed in Technology Preview Update Quick Layers Palette's "Hide Selection Layer" command didn't work in 3D view. Windows & macOS 2024-08-15
DEF-19440 fixed in Technology Preview Update White fill pen can't be distinguished from the white background on new Windows machines. Windows 2024-08-15
DEF-19170 fixed in Technology Preview Update Space key + right click shortcut didn't work on macOS Sonoma. macOS 2024-08-15
DEF-12273 fixed in Technology Preview Update Publishing a layout into DWG shows a warning message and keeps updating drawings even after all drawings are updated. Windows & macOS 2024-08-15
ADD-1 fixed in Technology Preview Update Archicad Library 27 will be added to Archicad Library 28, instead of using a separate Migration Library folder. Windows & macOS 2024-08-15
ADD-2 fixed in Technology Preview Update The Archicad 27 Monolith Library will be on the installer starting from Archicad 28 Technology Preview Update. Windows & macOS 2024-08-15
ADD-4 fixed in Technology Preview Update MEP Library 27 and 28 will both be installed with the Archicad 28 installer. Windows & macOS 2024-08-15
DEF-20189 fixed in Technology Preview Update Archicad could crash due to a Texture related background process. Windows & macOS 2024-08-15
Authors
