Graphisoft Technology Preview Program 2024
Section tool not working correctly since version 26
kev91
Hi friends.I use Archicad since 20 version.
When I make a section, fills do not appear or are mixed.
But they appear when I move them.
There is the same mistake in 26,27 and 28 versions.
I tried:
to change the order of visualization.
to change the intersection priority of the materials
and the layer levels.
It only works if I make a subtraction
That's why I still use 25 version.
Pen colors also look different on objects with the same configuration. Look at the beam.
If I open a project that works perfectly in 25 version , in 26, 27, 28 versions  they are deconfigured and have the same error.
I'm using a translator. I hope my comments are useful. Thanks.
Marc H
If it helps, I've been using ACv27 USA and have not had any performance issues in section view fills.  I have experienced some similar issues to what you noted, but I've found the issues are often found in one of these factors:
- The element requires a subtraction SEO operation (e.g., footing into mesh) to show its cut fill properly (as you noted).
- The element display order needs editing (which you also noted).
- The element has an override in its Plan & Section settings.
- There is a GOR affecting certain cut and cover fills based on applied criteria.
- The section settings have both a detail depth line and an extent depth line (or infinite).  Some elements will display differently as they fall beyond the detail depth line.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
kev91
I am from Paraguay. My friends have the same problem.
Marc H
thanks for your response!
