Following on from NateLumen's post "Working on tracking down Keynotes in the Keynote palette. If I select the keynote in the view it will be highlighted in the keynote palette...but only if the folder isn't collapsed. If it's collapsed, I get no indication where it is! Maybe either the folder could get highlighted, or opened and the keynote gets highlighted?"
We use use the Keynote add-on in Archicad 23, when selecting the keynote in the view, not only does it automatically open the folder in the keynote palette, it has a content box, that when you click on it, all the content of the selected keynote appears, is there a setting that I am missing, to make this happen?
Also noticed, like the 23 add-on, the easiest way to get symbols ° etc. into your keynote is to using the Windows emoji short cut, pressing "windows button and ."
