Graphisoft Technology Preview Program 2024
SOLVED!
Wish list: adding profiles to library elements
iggiv
Dear Team,
I understand that this is not a WISHING LIST Forum, but I am unsure where else to post this request.
I have deleted AC27 and am now exclusively using AC28. Everything seems to be working as expected, so I am transitioning to creating details. The Library Element tool, with its options for classifications and properties, is invaluable for organizing my project.
However, I find myself needing to create LED lighting strips, mounting channels, and window aluminum profiles when working on 1:20 details. Currently, I create a profile and use the column tool to place the element detail on the floor plan, then finish it up in the details window.
Would it be possible to add a profile option to the Library Element tool? This feature would significantly streamline the process.
1 ACCEPTED SOLUTION
Solution
vdentello
If you mean doing it to a GDL object, it's already doable.
It's just not so easy to code It for the first time, but you can find some posts by Heimo Mooslechner here and his YouTube channel, he even has the base objects available for download. You might like it.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
2 REPLIES 2
Solution
vdentello
GDL Developer
from Brazil
vDentello: I did not think of that!!! Great thank you, very nice videos!!!
